14 years agoSRAM Addressing in QSYS
Hello I'm using a DE2-115 board with 2 MB SRAM (Address width 20. Data width 16). I used Qsys "Generic tri state controller" to attach the memory to the NIOS processor. Problem: How to acc...
12 years agoHey on your SRAM what did you do with the SRAM_UB_N and SRAM_LB_N pins? Also, did you have to modify any of the values in the module assignments section? For example memory size, memory units (which I don't understand what a memory unit is) etc...?
