21 years agospi write/read time out
to what occurrence of these lines can be connected at loading a nucleus?
whether there was a similar situation at someone else? ------------------ Linux version 2.6.11-uc0 (SFx@lab1p4) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 5 Thu Aug 25 14:07:58 2005 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: root=/dev/mtdblock0 ro PID hash table entries: 128 (order: 7, 2048 bytes) spi_write time out
spi_read write address time out
spi_read write address time out Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory available: 14740k/16384k RAM, 0k/0k ROM (1196k kernel code, 255k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 SPI: Nios SPI bus device version 0.1 NIOS serial driver version 0.0 ttyS0 (irq = 4) is a builtin NIOS UART Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 Microtronix map: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. cmdlinepart partition parsing not available Searching for RedBoot partition table in Microtronix map at offset 0x7f0000 No RedBoot partition table detected in Microtronix map Using Microtronix development partition definition Creating 4 MTD partitions on "Microtronix map": 0x00200000-0x00700000 : "romfs" 0x00000000-0x00200000 : "loader/kernel" 0x00500000-0x00580000 : "usersapace" 0x00580000-0x00600000 : "other" blkmtd: version $Revision: 1.5 $ blkmtd: error: missing `device' name block2mtd: version $Revision: 1.1.1.1 $ VFS: Mounted root (romfs filesystem) readonly. Freeing unused kernel memory: 52k freed (0x114a000 - 0x1156000) expand: from=/ramfs.img to=/dev/ram0 expand: from=/ramfs.img to=/dev/ram1 SIOCSIFADDR=-1: 9 SIOCGIFFLAGS = -1: Bad file descriptor (9) SIOCADDRT=-1: 9 /bin/inetd: not found /bin/boa: not found /etc/issue www.microtronix.com June 2005 Welcome to Linux on the Nios II Nios2 login: --------------------
if such lines appear that spi interface does not work in uclinux.
thanks for the help!
1 Reply
Please check the hardware first,
is the SPI device fall to work or the lines of SPI not connected properly.
