12 years agoSPI slave code
Hi, I'm using the QSYS SPI module as a slave. The SPI slave is supposed to receive sequences of bytes/characters. In order to make this happen, I'm using some SW code that reads the stat...
12 years agoThe SPI master is using 1MHz as the baudrate, while the NiosII is running much faster at 50MHz, so I should be able to read the rxdata before the next byte arrives. Any code sample would be helpfull, since I'm not really a SW developer.
