12 years agoSPI slave code
Hi, I'm using the QSYS SPI module as a slave. The SPI slave is supposed to receive sequences of bytes/characters. In order to make this happen, I'm using some SW code that reads the stat...
12 years agoThe Altera spi core has no rx buffer; data would be overwritten if you don't read it before the next byte arrives.
Check also the receive overrun (ROE) bit in status register.
