20 years agoSPI PUZZLE
Hello, all
I have problems with SPI as follows. As you know, SPI is a 3 wire interface and a SPI should have 3 signals commonly, but in SOPC Builder, a SPI have 4 signals actully. They are sclk, ss_n, mosi and miso. Why? Generally speaking, a chip(such as TLV320AIC23B, which is a stereo audio codec) with SPI interface has 3 SPI pins, and they're clk, ss and data, which is a bidirector signal.Suppose that the SPI is configured as master, and an off-chip device with SPI interface is configured as slave. Then, how should I connect them? And what functions the signal of miso acts in this instance? Anyone can help me? Thanks.9 Replies
eltonlaonong,
MOSI means Master-Out-Slave-In and is the data line transfering data from a Clock-Master to a Clock-Slave. And so is MISO the other data line from Slave (Out) to Master (In). This is a full duplex connection with multiple slaves (each selected and activated by a own SS ) and one Master, who provides clock and all slave select signals (SS). Most of the SPIs use this organization. Mike - Altera_Forum
> Then, how should I connect them? Because SPI core data in/out port are mono-direction, but slave-device data port is bi-direction. So, you should add a tri-buffer to connect between device and master. ss_n is the output-en for tri-buffer. LiangYi - Altera_Forum
TLV320AIC23B datasheet:
Interface can work in SPI or I2C (twowire) mode in SPI Mode: SPI Signals are : \CS,SCLK and SDIN SDIN is input only in SPI Mode (it seems that register of AIC23 are write only) so connect MOSI with SDIN - Altera_Forum
--- Quote Start --- originally posted by fischer@Oct 10 2005, 05:59 AM tlv320aic23b datasheet:interface can work in spi or i2c (twowire) mode
in spi mode:
spi signals are : \cs,sclk and sdin
sdin is input only in spi mode
(it seems that register of aic23 are write only)
so connect mosi with sdin
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10261)
--- quote end ---
--- Quote End --- So, in Quartus II, how to deal with the signal of miso generated by SPI core in SOPC Builder? Thank you!
You can also look up at <n2cpu_nii5v3.pdf> Fig 7-4.
Something like as LiangYi said. - Altera_Forum
Refe to <n2cpu_nii5v3.pdf> Fig 7-4 .
something like as LiangYi said - Altera_Forum
--- Quote Start --- originally posted by eltonlaonong@Oct 10 2005, 07:08 PM so, in quartus ii, how to deal with the signal of miso generated by spi core in sopc builder? --- Quote End --- Tie it off to VCC or GND if you're not using it. The synthesizer will optimize out the unused registers that way. - Altera_Forum
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Thank u very much! I have made it clear with your help. Best regards!
