ASidd16
6 years agoSPI Mode
Hello Everyone.
I want to know how can i change SPI mode in NIOS software.
For example i have two chips, one chip has SPI mode 3 and the other has 1,
i want to use only one block in Qsys with 2 chip select pins.
If i configure it with mode 3 , the other chip is not working.
If anyone has an idea then please share.
Thank you
- SyafieqS
Hi Ali,
It is always recommended for you to start with sample design. You can find very good references about how to use SPI communication, here is a good example of how to use SPI slave to AVALON memory mapped.
- ASidd16
Thank you for your help.
but this is not the answer of my Question.
SPI is working properly. I want to change SPI mode using NIOS.
Thank you
