20 years agoSPI for nios
dear every1, i've been stuck with trying to tranfer data out the spi..i just dont know how to use it.i wanna use the alt_avalon_spi_command() but i just cant do it.i'm stuck witthe basic ...
20 years agoHi,
here is the code # include <stddef.h> # include "alt_types.h" /* * Macros used by alt_sys_init */ # define ALTERA_AVALON_SPI_INSTANCE(name, device) extern int alt_no_storage# define ALTERA_AVALON_SPI_INIT(name, device) while (0) /* * Use this function to perform one SPI access on your target. 'base' should * be the base address of your SPI peripheral, while 'slave' indicates which * bit in the slave select register should be set. */ /* If you need to make multiple accesses to the same slave then you should * set the merge bit in the flags for all of them except the first. */# define ALT_AVALON_SPI_COMMAND_MERGE (0x01) int alt_avalon_spi_command(alt_u32 base, alt_u32 slave, alt_u32 write_length, const alt_u8 * write_data, alt_u32 read_length, alt_u8 * read_data, alt_u32 flags); # endif /* __ALT_AVALON_SPI_H__ */ # include "alt_types.h" # include "altera_avalon_spi_regs.h"# include "altera_avalon_spi.h" /* This is a very simple routine which performs one SPI master transaction. * It would be possible to implement a more efficient version using interrupts * and sleeping threads but this is probably not worthwhile initially. */ int alt_avalon_spi_command(alt_u32 base, alt_u32 slave, alt_u32 write_length, const alt_u8 * write_data, alt_u32 read_length, alt_u8 * read_data, alt_u32 flags) { const alt_u8 * write_end = write_data + write_length; alt_u8 * read_end = read_data + read_length; alt_u32 write_zeros = read_length; alt_u32 read_ignore = write_length; alt_u32 status; /* We must not send more than two bytes to the target before it has * returned any as otherwise it will overflow. */ /* Unfortunately the hardware does not seem to work with credits > 1, * leave it at 1 for now. */ alt_32 credits = 1; /* Warning: this function is not currently safe if called in a multi-threaded * environment, something above must perform locking to make it safe if more * than one thread intends to use it. */ IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(base, 1 << slave); /* Set the SSO bit (force chipselect) */ IOWR_ALTERA_AVALON_SPI_CONTROL(base, ALTERA_AVALON_SPI_CONTROL_SSO_MSK); /* Keep clocking until all the data has been processed. */ for ( ; ; ) { do { status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0 || credits == 0) && (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); if ((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) != 0 && credits > 0) { credits--; if (write_data < write_end) IOWR_ALTERA_AVALON_SPI_TXDATA(base, *write_data++); else if (write_zeros > 0) { write_zeros--; IOWR_ALTERA_AVALON_SPI_TXDATA(base, 0); } else credits = -1024; }; if ((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) != 0) { alt_u32 rxdata = IORD_ALTERA_AVALON_SPI_RXDATA(base); if (read_ignore > 0) read_ignore--; else *read_data++ = (alt_u8)rxdata; credits++; if (read_ignore == 0 && read_data == read_end) break; } } /* Wait until the interface has finished transmitting */ do { status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0); /* Clear SSO (release chipselect) unless the caller is going to * keep using this chip */ if ((flags & ALT_AVALON_SPI_COMMAND_MERGE) == 0) IOWR_ALTERA_AVALON_SPI_CONTROL(base, 0); return read_length; }
