21 years agoSPI Example?
Hello Everyone, I'm working on a project that utilizes the SPI interface of the SOPC builder. I'm having some trouble getting it to work though, mostly because I'm not sure if I'...
21 years agoHello,
some sample code without comments, it talkes to a dsp via spi interface, NIOS is MASTER and DSP is slave perhaps it helps ...# include"global.h"# include"system.h"# include"hw_base.h" # include <unistd.h> # include"dspctrl_spi.h" # define INTWORD_DELAY 10 /* void dsp_write16(WORD *data,WORD len) { IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(SPI_0_BASE,BIT0); IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_0_BASE, ALTERA_AVALON_SPI_CONTROL_SSO_MSK); // spi_write_16(SPI_0_BASE,data,len); IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(SPI_0_BASE,BIT0); IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_0_BASE,0); } */ # define SLAVE0 0# define HREGSIZE 32 //############################################################################ void dsp_write_reg(BYTE reg,WORD data) { WORD tempdata[2]; tempdata[0]=CMD_FIRSTBYTE | (reg&(HREGSIZE-1)); tempdata[1]=data&~CMD_FIRSTBYTE; // spi_write_16(base,tempdata[0]); // spi_write_16(base,tempdata[1]); spi_write_block(SPI_0_BASE,SLAVE0,tempdata,2); spi_wait_TRDY(SPI_0_BASE); } //############################################################################ WORD dsp_read_reg(BYTE reg) { WORD tempdata[2]; // dsp checks first byte and knows then that he has to put some data on the bus tempdata[0]= CMD_FIRSTBYTE | CMD_READ | (reg&(HREGSIZE-1)); spi_write_block(SPI_0_BASE,SLAVE0,tempdata,1); // spi_write_16(base,tempdata[0]); spi_read_block(SPI_0_BASE,SLAVE0,tempdata,1); return tempdata[0]; } //############################################################################ void spi_write_block(DWORD base,BYTE slave,WORD *data,DWORD len) { DWORD i; for(i=0;i<len;i++) { spi_select_slave(base,slave); spi_write_16(base,(*data++)); spi_deselect_slave(base,slave); usleep(INTWORD_DELAY); } } //############################################################################ void spi_read_block(DWORD base,BYTE slave,WORD *data,WORD len) { WORD i; for(i=0;i<len;i++) { spi_select_slave(base,slave); *data++=spi_read_16(base); spi_deselect_slave(base,slave); usleep(INTWORD_DELAY); } } //############################################################################ void spi_select_slave(DWORD base,DWORD slave) { IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(base, 1 << slave); // Set the SSO bit (force chipselect) IOWR_ALTERA_AVALON_SPI_CONTROL(base, ALTERA_AVALON_SPI_CONTROL_SSO_MSK); } //############################################################################ void spi_deselect_slave(DWORD base,DWORD slave) { IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(base, 1 << slave); // reset the SSO bit (force chipselect) IOWR_ALTERA_AVALON_SPI_CONTROL(base,0); } //############################################################################ void spi_write_16(DWORD base,WORD data) { DWORD status; do { status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while ((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0); IOWR_ALTERA_AVALON_SPI_TXDATA(base,data); } //############################################################################ WORD spi_read_16(DWORD base) { DWORD status; WORD data; IORD_ALTERA_AVALON_SPI_RXDATA(base); IOWR_ALTERA_AVALON_SPI_TXDATA(base,0x00); do { status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while ((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); data=IORD_ALTERA_AVALON_SPI_RXDATA(base); return data; } /* void spi_write_16(DWORD base,BYTE slave,WORD *data,DWORD len) { DWORD i; DWORD status; IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(base, 1 << slave); for(i=0;i<len;i++) { // select slave IOWR_ALTERA_AVALON_SPI_CONTROL(base, ALTERA_AVALON_SPI_CONTROL_SSO_MSK); do { status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while ((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0); // deselect slave IOWR_ALTERA_AVALON_SPI_CONTROL(base, 0); IOWR_ALTERA_AVALON_SPI_TXDATA(base,*data++); } while ((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0); } */ void spi_wait_TRDY(DWORD base) { DWORD status; do { status = IORD_ALTERA_AVALON_SPI_STATUS(base); } while ((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0); }
