21 years agoSpeedup of NIOS2?
Hello!
How I can speedup of execution my program on NIOS 2? I'm trying to make calculation of video data before output it to monitor, but cpu makes it very slowly. I want to calculate video sprites and alpha chanal. System clock and SDRAM clock are 100 MHz, Nios CPU is f-version with icash=2K and dcash=1K, I'm using EP1C6Q240C6. Program memory and video memory are working on the different SDRAM controllers (2 video chips and 1 program chip). The data to video controller are transmitting by DMA. For example this operation execute very slowly: ***** unsigned char *mem = ... program memory //(16 bits data bus) unsignde char *vmem = ... video memory //(8 bits data bus) ***** //Write to video memory some sprite for (int i=600; --i; ) for (int j=800; --j; ) if (*mem != 0xF7) { *--vmem = *mem; mem--; } ***** //Transmitting to VGA IOWR_ALTERA_AVALON_DMA_STATUS(SD_DMA_BASE, 0); IOWR_ALTERA_AVALON_DMA_RADDRESS(SD_DMA_BASE, (int)vmem); IOWR_ALTERA_AVALON_DMA_WADDRESS(SD_DMA_BASE, SD_BASE); IOWR_ALTERA_AVALON_DMA_LENGTH(SD_DMA_BASE, 800*600); IOWR_ALTERA_AVALON_DMA_CONTROL(SD_DMA_BASE, 0x02DC); ****** I need to do this cycle about for 25-30 times per second, but really it works only for 5-10 times per second. How I can speedup this block? Maybe someone had the same problem before or has any idea? Thanks.1 Reply
See your identical post in the General section, I left my answer there.
