20 years ago
Speed problem with EPCS
Hello all together,
i have an problem with the EPCS.
After I load my Software with the Flashprogrammer in the EPCS and restart my Device, it takes around 25s till my programm starts.
I measured the CONFIG_DONE and the DCKL-Lines at EPCS.
The result is, that the Cyclone2-Device loads the FPGA-Design-File correct (with correct Speed), and then transfer the Software with very low Speed from EPCS to SDRAM (200 KB in 20s).
The Hardware-Platform is fully tested (an other Design functions without this problem).
The Flashprogrammer-design works too (the same design works with another project).
Extra_delay option in EPCS-Source-class is set to "0".
Here my IDE Infos:
Quartus 5.0 SP1
NIOS2 5.0 SP1
I hope anyone can help me!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
greetz MIBU
    DO NOT use v5.0. You should use v5.1 sp1, or the latest v6.0 . Altera had improved the speed.
    there was a fix posted here for the epcs boot loader code i guess ....
