20 years agoSource control and automatic build
Hi All, I'm currently using Subversion as a source control system for Nios projects (both hardware and software). The Nios projects are easily kept under source control (it's probably poss...
20 years ago --- Quote Start --- originally posted by avishorp@Jun 14 2006, 04:37 AM hi all,
i'm currently using subversion as a source control system for nios projects (both hardware and software). the nios projects are easily kept under source control (it's probably possible to use subclipse, but i do it manually), but as far as i know, the workspace cannot be source controlled. two problem arise from this fact:
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16169)
--- quote end ---
--- Quote End --- I'm using darcs and I have exactly the same issues. Eclipse makes it _really_ hard to move a project. Why IDE applications insist on using absolute paths I'll never know. I'm currently mucking about with the .xml files in the .metadata directory to see If I can figure out something that works.
