21 years agoSound Card for uClinux
I see the uClinux 2.6 has support for a sound driver. Apparently you can just use "cat" to send the raw audio to the sound card at /dev/dsp.
Can you tell me what sound daughter card I can use, that will work with this driver. Also, how about interfacing, do you just define the I/O pins in the Quartus design?2 Replies
Maybe:
http://www.fpga.nl/ (http://www.fpga.nl/) Jester or Lancelot... Does uClinux 2.6 has a c code file to drive it?? - Altera_Forum
Thanks, the Jester board on fpga.nl (http://www.fpga.nl) is just about what I'm looking for, except I would like to play PCM audio.
<div class='quotetop'>QUOTE </div> --- Quote Start --- Does uClinux 2.6 has a c code file to drive it??[/b] --- Quote End --- It would seem so. uClinux has a driver for ALSA (Advanced Linux Sound Architecture) but I have no idea if it would work with an audio expansion card
