20 years agoSOPC Module with 2x Avalon Master and Avalon Slave
The more i work with nios the more funny task have to be solved :-) As mentioned in a previous topic, i had designed an 8 bit avalon master. But we had to change the design to 32bit due to pe...
20 years agoHello Michael,
I think you only need one clock in the Component Editor if you select the interface “global_signals” in the Signals Tab. Regards, niosIIuser
