20 years ago
SOPC builder
Hi to all,
it&#39;s very strange the SOPC builder&#39;s behaviour in QII 6.0, in fact if I try to create a new component (previously simulated alone), SOPC gives the error number 3 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif , this I think because my component uses modules inside other files (or libraries), in the contrary, if I include all the requested modules inside the file of the component I want to instantiate in SOPC builder, everything works well http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif .
Can anyone explain this strange behaviour?
    I have the same problem with QII 5.1 SP2.01
    I try to create a new component in SOPC Builder (open cores uart16550)
    I put all verilog files in a directory under the quartus project directory
    /src/uart16550
    raminfr.v
    timescale.v
    uart_debug_if.v
    uart_defines.v
    uart_receiver.v
    uart_regs.v
    uart_rfifo.v
    uart_sync_flops.v
    uart_tfifo.v
    uart_top.v
    uart_transmitter.v
    uart_wb.v
    I start component editor and add all the above hdl files, it starts green blinking,
    2 files are ok then error occures
    Error: command "quartus_map --generate_hdl_interface=C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v ce_temp_directory/ce_temp_quartus_project" returned 3
    Error (10054): Verilog HDL Compiler Directive error at uart_debug_if.v(90): can&#39;t open Verilog Design File "uart_defines.v" File: C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v Line: 90
    Error (10112): Ignored module "uart_debug_if" at uart_debug_if.v(92) due to previous errors File: C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v Line: 92
    Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
    Error: Processing ended: Tue Jul 25 20:03:15 2006
    Error: Elapsed time: 00:00:01
    Error: C:/work/pro/8dio010_server/8DIO010_FPGA/ce_temp_directory/uart_debug_if.v.xml does not exist
    after all errors I cannot select uart_top as top level module
    can someone please help me because I only know vhdl and not much verilog,
    has anybody already created this uart in sopc builder ?
    thanks
    I tried to do in your way, but, of course doesn&#39;t work.
    I think the only chance you have is to create a single file with everything inside.
