21 years agoSOPC Builder
ciao to everybody I'm trying to build a new system with cpu nios 2 , sdram ,tristate bridge and my user component I import my component vhdl file and i declare 2 port that in slave are ...
21 years agoSOPC builder generate MySystem and all files .
The file i think most importat is the "class.ptf" that describe my system including my component . Here i can see my declarations , like as i wrote up , in the preview post . PORT_WIRING { PORT clk { width = "1"; direction = "input"; type = "clk"; } PORT i1 { width = "1"; direction = "input"; type = "reset"; } PORT i2 { width = "1"; direction = "input"; type = "write"; } PORT i3 { width = "32"; direction = "input"; type = "writedata"; } PORT i4 { width = "32"; direction = "input"; type = "writedata"; } PORT i5 { width = "32"; direction = "input"; type = "writedata"; } PORT i6 { width = "32"; direction = "input"; type = "address"; } PORT o1 { width = "1"; direction = "output"; type = "export"; } PORT o2 { width = "1"; direction = "export"; type = ""; } } } SIMULATION { DISPLAY { SIGNAL a { name = "clk"; } SIGNAL b { name = "i1"; } SIGNAL c { name = "i2"; } SIGNAL d { name = "i3"; radix = "hexadecimal"; } SIGNAL e { name = "i4"; radix = "hexadecimal"; } SIGNAL f { name = "i5"; radix = "hexadecimal"; } SIGNAL g { name = "i6"; radix = "hexadecimal"; } SIGNAL h { name = "o1"; } SIGNAL i { name = "o2"; } } } } Ok now the system knows my component. How may i write the low-level library to enter and interface it with Nios II IDE ? Don't fight me , be patient It's only ten days i'm starting with altera fpga and this world thanks walter
