21 years agoSOPC Builder
ciao to everybody I'm trying to build a new system with cpu nios 2 , sdram ,tristate bridge and my user component I import my component vhdl file and i declare 2 port that in slave are ...
21 years agothis is a simply clock divider , and this my component i want to
integrate in my system by SOPC . I added I3,I4,I5 just to see what appen in sopc builder library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity provaprogetto2 is Port( clk:in STD_LOGIC; I1:IN STD_LOGIC; I2:IN STD_LOGIC; I3:in unsigned(31 downto 0); I4:in unsigned(31 downto 0); I5:in unsigned(31 downto 0); I6:in unsigned(31 downto 0); O1:OUT STD_LOGIC; O2:OUT STD_LOGIC); end entity provaprogetto2; architecture div_clock of provaprogetto2 is signal clk_cnt : unsigned(32 downto 0); signal mem:STD_LOGIC; signal sec:unsigned(7 downto 0); signal min:unsigned(32 downto 0); begin process(clk,I2) begin if (I2='0') then clk_cnt<="000000000000000000000000000000000"; mem<='0'; sec<="00000000"; min<="000000000000000000000000000000000"; O2<='1'; elsif (clk='1') and (clk'event) then if (clk_cnt=33000000) then clk_cnt<="000000000000000000000000000000000"; mem<=not mem; min<=min+1; if(min=2) then O2<='1'; end if; else clk_cnt<=clk_cnt+1; end if; if(min=60) then O2<='0'; min<="000000000000000000000000000000000"; end if; end if; end process; --O2<=I1; O1<=mem; end architecture div_clock; When i import this component , SOPC got an address memory base=0x00000800 and end=0x00000803 I declare my inputs "I1,....I5" like address or writedata , or readdata I declare different way to see what happen , ...but nothing happen I generate and SOPC told me "Ok , all generates whitout problems " Ok ,i thank , but now how can i interface my component input I1....I5 with my application IDE Nios II ? Ok i must to write header files and driver files , but wich addrress i need to use , for example for I1 (it's a bool ) where i find it ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif I think it's difficult to explain , now i want to finish to read Quartus II Volume 4 SOPC Builder thank to everydody http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif ciao walter
