21 years agoSOPC builder
I began my project and now I begin to understand all the advantages of the NIOS. I have to plug a CMOS video sensor to my NIOS II evaluation board. Would it be better for me to use the SOPC builder to decalre this new component. Or do I have to connect it myself with the hardware already created by the SOPC (PIO, CPU + SDRAM)? Do you have any advice for me to plug the camera? Thank You. Romain.23 Replies
<div class='quotetop'>QUOTE </div>
--- Quote Start --- When I use the signal address, how can I know what will be those addresses, knowing that in SOPC builder, there are no adresses pre-assigned (as it is a master).[/b] --- Quote End --- I've built an Avalon Master too and i had the same problem. To solve it, i've built also an Avalon slave port in my peripheral: in this way, Nios processor could inizialize some registers of the peripheral to set the correct address for the avalon master port. The waitrequest is automatically sent by the avalon bus each time that the peripheral has to wait, as you said. Your Avalon master port have only to manage correctly this waitrequest. - Altera_Forum
I've found this example, for those for want also to make a master peripheral. memory filler (http://www.niosforum.com/forum/index.php?act=st&f=15&t=508&hl=master) I hope that I will be soon able to give you my master peripheral http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif Bye. - Altera_Forum
--- Quote Start --- I've built an Avalon Master too and i had the same problem. To solve it, i've built also an Avalon slave port in my peripheral: in this way, Nios processor could inizialize some registers of the peripheral to set the correct address for the avalon master port.[/b] --- Quote End --- Hello Soin, When you told me that you created both a master and a slave in your peripheral, did you mean in the same UIL? Because in this case, I don't see how to make correspond registers of the two interfaces. Thank you. Romain. - Altera_Forum
Hi Nofi,
UIL is User Interface Logic? If so you are using the old SOPC utility made for Nios I. Instead now u have "Create new component" for Nios II, a utility that allows you to define an interface to your logic and so on. In this case, u can define as much avalon interface (master or slave) as u want, for the same peripheral. - Altera_Forum
Yes I mean User Interface Logic when I say UIL. SO thaznk you very much for the answer, I didn't know anything about this utility. Do you know wether in this case, I'm obliged to use an avaloin clock ,or can I use the clock of my off-chip peripheral? - Altera_Forum
Hi Nofi,
for tha avalon master port you are obliged to use an avalon clock input (you will receive an error message from the "Create new component" interface"). For the avalon slave port there are no error messages, but in my peripheral i've used avalon input clock for both master and slave...and it works... - Altera_Forum
ok, the problem is that my peripheral and Avalon don't have the same clock.
I think I will change the clock of the avalon then. Thank you again! - Altera_Forum
Hi all,
Finally, we decided to make something as simple as possible, and to compensate with the power of the NIOS II. Is it possible to use only export signals? The data from my sensor would go into a register. Then in the NIOS IDE, I would read registers (registre_ecriture) thanks to IORD. How can I know the addresses of my registers? <div class='quotetop'>QUOTE </div> --- Quote Start --- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; entity juste_le_slave is port ( --entrées externes data : in std_logic_vector(7 downto 0); --export, data from the sensor vsyn : in std_logic; --export pclk : in std_logic; --export href : in std_logic; --export read : in std_logic; --avalon readdata : out std_logic_vector(7 downto 0) --avalon ); end; architecture a of juste_le_slave is signal registre_ecriture : std_logic_vector(7 downto 0);signal registre_controle : std_logic_vector(7 downto 0); begin process(pclk) begin if(pclk'event AND pclk='1' AND read='1') then if (href='1') then if (registre_controle="00000000") then registre_controle<="11111111"; end if; registre_ecriture<=data; else if(vsyn='1') then registre_controle<="00000000"; end if; end if; end if; if (registre_controle="0000000") then readdata<=registre_controle; else readdata<=registre_ecriture; end if; end process; end a;[/b] --- Quote End ---
Has anyone already seen those errors, when building a project: *** [obj/alt_sys_init.o] Error 1 *** [system_project] Error 2 error: 'ALT_IRQ_NOT_CONNECTED' undeclared (first use in this function)[system_description/alt_sys_init.c] error: (Each undeclared identifier is reported only once[system_description/alt_sys_init.c] It appears when I compile this code:#include <stddef.h># include “sys/alt_dma.h”# include <stdio.h># include <stdlib.h># include “alt_types.h” /* flag used to indicate the transaction is complete */ volatile int dma_complete = 0; /* function that is called when the transaction completes */ void dma_done (void* handle, void* data) { dma_complete = 1; } int main (void) { alt_u8 buffer; alt_dma_rxchan rx; /* Obtain a handle for the device */ if ((rx = alt_dma_rxchan_open (“/dev/dma”)) == NULL) { printf (“Error: failed to open device\n”); exit (1); } else { /* Post the receive request */ if (alt_dma_rxchan_prepare (rx, buffer, 326688, dma_done, NULL)< 0) { printf (“Error: failed to post receive request\n”); exit (1); } alt_dma_rxchan_ioctl(rx, ALT_DMA_SET_MODE_8, NULL); alt_dma_rxchan_ioctl(rx, ALT_DMA_RX_STREAM_ON, (void*) INTERFACE_BASE); dma_complete = 0; /* Wait for the transaction to complete */ while (!dma_complete); printf (“Transaction complete\n”); alt_dma_rxchan_close (rx); } return 0; } - Altera_Forum
Hi Nofi,
I think you haven't connected the DMA interupt in SOPC. Use System->Auto-assign irqs tab in SOPC...
