21 years agoSOPC builder
Hello, I began my project and now I begin to understand all the advantages of the NIOS. I have to plug a CMOS video sensor to my NIOS II evaluation board. Would it be better for me to use the...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- I've built an Avalon Master too and i had the same problem. To solve it, i've built also an Avalon slave port in my peripheral: in this way, Nios processor could inizialize some registers of the peripheral to set the correct address for the avalon master port.[/b] --- Quote End --- Hello Soin, When you told me that you created both a master and a slave in your peripheral, did you mean in the same UIL? Because in this case, I don't see how to make correspond registers of the two interfaces. Thank you. Romain.
