16 years ago
SOPC builder problem
i'm new with Quartus II, nios II IDE and cyclone II..i got some problem when running my program using Quartus II, nios II IDE and cyclone II...
how can i generate high_res_timer.v from SOPC builder, is it by adding interval timer b4 generate SOPC builder.. and when i run nios II IDE, it cannot read the .zipfile in the program. can someone explain to me :confused: ... thank alot
1 Reply
    hello..
    i'm finally can generate my .sof file succesfully...
    then i run my program at nios II IDE, but when i want to generate my flash programmer i got this error:
    # Programming flash with the read only zip file system
    "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 --sidp=0x034420d8
    --id=615295035 --timestamp=1268367584 "rozipfs.flash"
    There are no Nios II processors available which match the values specified.
    Please check that your PLD is correctly configured, downloading a new SOF
    file if necessary.
    can someone explain to me??? i really clueless:(
