20 years agoSOPC builder module names for a µCLinuy system
Hi guys, I'm creating an CycloneII system with the SOPC builder, on which later µCLinux must run. The system contains: - system clock timer - timer for free use - i2c master p...
20 years agoYou don't have to use special name for the devices.
Just use the default name given by spoc_builder. The kernel building process use hwselect.pl to generate nios2_system.h, which match the ports address. make ARCH=nios2nommu O=/usr/local/src/nios2/build/kernel CROSS_COMPILE=nios2-elf- hwselect STSPTF=/usr/local/src/nios2/build/yoursystem.ptf The system timer should be a default , full featured timer. You should have a SDRAM or DDR SDRAM device to run the program. You should also have a Jtag or UART for console to debug. It looks like you will write or debug kernel drivers. It is strongly recommanded that you build the tools chain and develop on Linux platform.
