21 years agoSOPC BUILDER, FLASH PROGRAMMER DIRECTORY PROBLEM
SOPC BUILDER and FLASH PROGRAMMER DIRECTORY PROBLEMS I always make copies of directories with projects. When I make a new component with "Interface to User Logic" and add it to the libra...
21 years agoThanks Nate,
I will check the the SOPC Builder Setup,I have seen that there are listed some old directories. however I think it's more save to keep a copy of the component in the actual project directory, because components will change with time. When I have a look at the SOPC Builder Setup help, Is the following directory search order correct ? 1. Additionals directories in SOPC Builder Setup 2. current project directory 3. build in SOPC Builder component directory ("altera\kits\nios2\components") I think the following is not correct, (Right click on component -> Component Details -> Location) shows correct path of component in actual project, but files are taken from another directory, if the project is regenerated. It would be helpfull, if in the generation process would show the path and file for each component it find's. For the flash programmer it would be better, if the user can manually enter the directory and filename of the board.sof file.
