21 years agoSOPC BUILDER, FLASH PROGRAMMER DIRECTORY PROBLEM
SOPC BUILDER and FLASH PROGRAMMER DIRECTORY PROBLEMS I always make copies of directories with projects. When I make a new component with "Interface to User Logic" and add it to the libra...
21 years agoThanks Nate.
My confusion was that the flash document says to use 'Unspecified Board' as a target for the flash programmer project. I guess in this context it means 'programming' target instead of 'execution' target. This does not explain all the other times the flash utility wouldn't work for me. I am now using the tactic of closing everything, reopening and rebuilding everything whenever there is a problem like this. See the thread 'Programming EPCS via NiosII IDE' http://www.niosforum.com/forum/index.php?a...ct=st&f=2&t=373 (http://www.niosforum.com/forum/index.php?act=st&f=2&t=373)
