20 years agoSOPC Builder Components WITHOUT a NIOS?
I was under the assumption that you could use some of the SOPC builder components without a NIOS. For example if I wanted an SPI interface to my FPGA logic I could create an SPI to Avalon bus interfa...
20 years agoHi cyclone,
> if I wanted an SPI interface to my FPGA logic I could create an SPI to Avalon bus > interface in SOPC builder and use it in my design. Is this true? Yes, but you will have to provide a bridge between your external logic and the Avalon bus. This is normally a slave interface to your external logic (e.g. a slave for your external CPU bus) and a master for the Avalon bus. Regards, --Scott
