20 years agoSOPC Avalon Timing
Hi ,
When I add a component to my system using SOPC Builder , I am not sure of what values I should enter for Avalon Timing (Setup , Read Wait , Write Wait , Hold , Read latency). How can I determine the exact values for these parameters ? Thank you, Quan2 Replies
hello quan1328
first it depends if it's an external component. if yes, then you must have a look into the datasheet and timing for this component. if it is an internal component, then you determine the timing with your vhdl or verilog code. for internal components, i use the waitrequest avalon signal to handle the timing. then you don't have to enter the avalon timing values. e.g. reading a register from an internal component requires e.g. 1 clock cycle, while reading from a fifo or other ram component normally needs 2 or 3 clock cycles. see 3.2.2 Slave Read Transfer, Wait states http://altera.com/literature/manual/mnl_avalon_spec.pdf (http://altera.com/literature/manual/mnl_avalon_spec.pdf) - Altera_Forum
--- Quote Start --- originally posted by fischer@Aug 17 2006, 11:32 PM hello quan1328first it depends if it's an external component.
for this component.
clock cycles.
see 3.2.2 slave read transfer, wait states
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17685)
--- quote end ---
--- Quote End --- Hi Fischer, I am reading the pdf you suggested . Thank you very much, Quan
