21 years agoSOPC and async sram how ?
Hello. I want to run the Nios II Cpu on an Cyclone Board with async Sram. My problem is i don't know how to glue the avalon bus together with my 256k*16 async sram. Altera provides only...
21 years agoHello BadOmen.
Thanks for answering. The Filterorders and coefficents are calculated by matlab. I will upload these datas via my host pc software to the nios cpu. The nios should than disable or enable some of the TAP's or biquad sections to get the right filterorder. The filters should be on the fpga. For the coefficents i have thought about an lookup table feed by the nios cpu but i have no idea on how to do this http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif The filter should work on 100Mhz if possible. The AD converter is connected to the cyclone. I'm a newbee and i have no idea on how to begin so any guidelines or code segments to get an introduction are welcome. What should i do first ? Thanks Andreas
