21 years agoSOPC 5.0 Compile error?
Hello, I get a very strange message during SOPC compilation that occurs during the generation of the CPU: The message is : ERROR: In object ' ' of class e_dpram: can't a...
21 years agoHi Ray,
Ok, understood ;-) Well we are much closer to being done with 5.0 -- I suggest that if you haven't already done so, obtain a more recent copy and that should clear things up.. these sorts of things are not uncommon in early pre-release builds and (should) get caught by the QA process. There was a problem of arbitration generation taking a while, depending on the system, that could take system generation take quite a long time (but not stuck forever as you describe) -- this was recently addressed.
