16 years agoSOPC + external Vhdl simulation
Hi, I'm programming 2 CycloneIII FPGAs (everything on PC, no HW), the 1st is simply a system of vhdl files interconnected each other, in the 2nd i've created a SOPC system as follows: ...
16 years ago --- Quote Start --- I would try first to connect the custom hardware to the SOPC inside one FPGA for example over an AVALON MM interface. --- Quote End --- That's exactly what i'm trying to do. The connection with the other FPGA is not a problem. --- Quote Start --- For simulation your custom hardware together with the SOPC you can expand the testbench which is generated during SOPC building. I case you are using VHDL the file <your_toplevel_name>_sopc.vhd contains a section: -- <ALTERA_NOTE> CODE INSERTED BETWEEN HERE --add your libraries here -- AND HERE WILL BE PRESERVED </ALTERA_NOTE> entity test_bench is end entity test_bench; ... Here you can instantiate your components. Additional you have to compile your sources in modelsim. --- Quote End --- I will try this option :) and let you know.. Sorry but i didn't understand this: --- Quote Start --- In Altera Version 7.2 I changed the setup_sim.do script in the <your_toplevel_name>_sopc_sim subdirectory. --- Quote End ---
