20 years agoSomething strange with SOPC
I tried editing component and then has got error. "Error: command "quartus_map --generate_hdl_interface=C:/projects/NIOS_JPEG/ce_temp_directory/avalon_adv202.v ce_temp_directory/ce_temp_quartus...
20 years agoOH NO ! ? ?????
If you have statemachines you would code something like : // statemachine definition //------------------------ parameter [2:0] /* synopsys enum states */ PLL_IL = 3'd0, PLL_FL = 3'd1, PLL_RC = 3'd2, PLL_NC = 3'd3, PLL_GO = 3'd4; // define state variable(s) reg [2:0] /* synopsys enum states */ pll_init_state; // synopsys state_vector pll_init_state If i understand that what you have posted here right, then the sopc component editor cannot handle parameter [x:y] but quartus can. I had a quick look at ALL sources where i had these problems as posted before and ALL have this parameter with [x:y]. Now i understand why i can work with sopc component editor if there are no statemachines in verilog. Now it is clear, Quartus SOPC has a Bug if the component sources have verilog statemachines. I hope this BUG gets fixed soon. Altera ???? And for the future ... i wish i would get a clear message that tell why what and where instead of error 3 or 10000 ... Regards. Michael Schmitt
