20 years agoSomething strange with SOPC
I tried editing component and then has got error. "Error: command "quartus_map --generate_hdl_interface=C:/projects/NIOS_JPEG/ce_temp_directory/avalon_adv202.v ce_temp_directory/ce_temp_quartus...
20 years agoHi all!
from altera parameter [3:0] will define the data as the vector signal. however, the parameter defines the data to be integer. as you know, in the code design, the bit width define is not so necessary for the parameters. Very excellent! Not so necessary width define has rised error! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
