20 years agoSomething strange with SOPC
I tried editing component and then has got error. "Error: command "quartus_map --generate_hdl_interface=C:/projects/NIOS_JPEG/ce_temp_directory/avalon_adv202.v ce_temp_directory/ce_temp_quartus...
20 years ago --- Quote Start --- originally posted by mschmitt@Mar 23 2006, 12:09 PM i have the same problems here.
sometimes we also see only that quartus_map returned error 3 but starting quartus_map from a command prompt did not show where the problem is.
this message can get more wore worse if you just get the information about a quartus message (10000) without any notice why what where ... and if you just compile the sourcefile with quartus you wont get any warning or error.
the only thing we discovered here is that if the sourcefile the sopc wants to use for a custom component has parameters used by some state machines (we use verilog) then we get these error messages returncode 3 and / or quartus message id 10000.
now we currently modify the ptf files by hand as the sopc is now unable to create a component out of the source file but quartus is still very happy to compile the stuff.
btw has anybody found a documentation what these message id's 3 or 10000 (and others) mean ?
regards.
michael schmitt
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13714)
--- quote end ---
--- Quote End --- Dear Michael Schmitt! We are wating response from altera now. When we would get it I could give it to all.
