11 years agosome questions about nios
hi everyone, i am new to nois, i encouter some problems in my project: 1. sysid and timesteap errors when i start to run or debug in eclipse i meet the sysid and timesteap errors for several t...
11 years ago --- Quote Start --- Hi. [1] Don't click on Run as NIOS... but click on Run Configurations, this will re-read the values if present and you will not get this error in a high frequency again. [2] There are to few information given. [3] This is also the way I do, but if someone say it is wrong, please do... Sometimes HDL-Signal-Names are replaced due to reduction of logic inside the synthesis, so the wire exists, but with an other name, but ST will be placed correctly. [4] You can click on the Compilation report after re-opening the project. It is located (should be) the fifth symbol on the top, or is located at the menu <Processing> or via Shortcut Cntrl+R I hope this helps --- Quote End --- and i add 2 questions, can you give me more advise? thanks a lot !!
