20 years agoSome problems with uclinux
Hi I met following problems when I am building standard linux tasks. ->Creating a ram disk image of ext2 fs problem My cf card is ok and creating an ext2 fs successfully.But the nex...
20 years agoI login NiosII board OK and can creat new folders by ftp. I can't see them in the LeapFTP window,But they can be found by the console. Why? Can anyone help me?
--- Quote Start --- originally posted by singerpop@Oct 22 2005, 02:17 PM hi
i met following problems when i am building standard linux tasks.
->creating a ram disk image of ext2 fs problem
my cf card is ok and creating an ext2 fs successfully.but the next step for creating a ram disk image always does not rool my hoop.
# dd if=/dev/zero of=/dev/ram0 bs=1k count=1024] <div class='quotetop'>quote </div>
--- quote start ---
/dev/ram0:no space left on device
4097+0 records in
4096+0 records out --- Quote End ---
# mke2fs -s0 -vm0 /dev/ram0 1024
# tune2fs -i 0 /dev/ram0
# mount /dev/ram0 /mnt
# umount /mnt
# dd if=/dev/ram0 of=ramfs1024.img count=1024 <div class='quotetop'>QUOTE </div> --- Quote Start --- ramfs1024.img:Read-only file system[/b] --- Quote End --- # mount –n /dev/hda1 /mnt/ide0# dd if=/ramfs1024.img of=/dev/ram0 <div class='quotetop'>QUOTE </div> --- Quote Start --- /ramfs1024.img:No such file or directory[/b] --- Quote End --- It seems that the ram image is not created. -->Ftpd problem I can connect and login Ok,but I can't upload. It's read-only. How to create a rw fs? Thank you! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=10524)</div> [/b] --- Quote End ---
