20 years agosome problem when make ModuleProgarmming
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif Hi all,
I make ModuleProgarmming fowing the http://nioswiki.jot.com/wikihome/operating...duleprogarmming (http://nioswiki.jot.com/wikihome/operatingsystems/moduleprogarmming). But I met some problem:Could anyone tell me where is wrong? The following is some messages in the red hat linux when I run "make odules_install" afer I run "rm user/busybox/busybox" and "make": INSTALL drivers/misc/hello.ko if [ -r System.map -a -x ../user/busybox/examples/depmod.pl ]; then ../user/busybox/examples/depmod.pl -k vmlinux -ae -F System.map -b /home/w/uClinux-dist-test/romfs/lib/modules -r 2.6.16-uc0; fi Unknown option: ae Unknown option: r make[1]: Leaving directory `/home/w/uClinux-dist-test/linux-2.6.x' The following is the messagesb in the nios2 command shell: /> modprobe hello insmod: cannot insert `/lib/modules/2.6.16-uc0/kernel/drivers/misc/hello.ko': Invalid module format (-1): Exec format error modprobe: failed to load module hello />No RepliesBe the first to reply
