21 years agoSome probem in starting up kernel from U-Boot
Hi all: With Scott's great help,i have succeed in building the U-Boot for my UP3 board. Use the new CFI code in the latest u-boot code__http://www.psyent.com/download But the fla...
21 years agoHi all:
Now the own mtd map is created, but there is the tired error info appears: RAMDISK driver initialized: 8 RAM disks of 1024K size 1024 blocksize
UP3: mtd map: 00200000: 00200000 bytes
UP3: mtd map: virt: 00200000
Creating 1 MTD partitions on "UP3 Development Board":
0x00100000-0x00200000 : "cramfs"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 17
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 60k freed (0x1188000 - 0x1196000)
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
As one partition, the Kernel command line is root=/dev/mtdblock0 ro. Hope someone have a good way to fix this problem. Thank you very much!:-) Best Regards! Justin
