21 years agoSome probem in starting up kernel from U-Boot
Hi all: With Scott's great help,i have succeed in building the U-Boot for my UP3 board. Use the new CFI code in the latest u-boot code__http://www.psyent.com/download But the fla...
21 years agoHi Scott:
Thanks you!When this flash utilities is completed, it's very convenience to download kernel and filesystem to flash. But now, i use the flash-program in NIOSII IDE to complete the flash function.Also it works good. So how to fix this kernel panic below, i try to fix it ,but no result.Hopefully you have a good idea:-) Thank you!Creating 1 MTD partitions on "RAM":
0x00000000-0x14005000 : "ROMfs"
microtronix: set ROMfs to be root filesystem
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
NET: Registered protocol family 1
NET: Registered protocol family 17
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 60k freed (0x11b6000 - 0x11c4000)
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel. Best Regards! Justin
