16 years agoSome help in application selector example
Can anyone explain this function to me (I mean explaining each statment in this function and how does it work) Note : This function is included in the app_selector_gui.c in the appication selector example which works on the Nios II embededd Cyclone III edition . int AsPrerenderFont( unsigned char* rendered_letters[], struct abc_font_struct font[], int fg_color, int bg_color ) { int i; // We're going to use the video library functions to render this, and // since those functions expect an alt_video_display type to which to write, // we create a small temporary one here and fill it out just enough to draw // to it. alt_video_display* temp_buffer; temp_buffer = (alt_video_display*) malloc(sizeof (alt_video_display)); temp_buffer->color_depth = 32; temp_buffer->num_frame_buffers = 1; temp_buffer->bytes_per_pixel = ( 4 ); temp_buffer->buffer_being_written = 0; temp_buffer->buffer_ptrs[0] = (alt_video_frame*) malloc( sizeof( alt_video_frame )); for( i = 0; i < 94; i++ ) { temp_buffer->width = font.bounds_width ;temp_buffer->height = font.bounds_height; temp_buffer->bytes_per_frame = (( temp_buffer->width * temp_buffer->height ) * 4 ); temp_buffer->buffer_ptrs[0]->buffer = (void*) malloc( temp_buffer->bytes_per_frame ); vid_print_char_alpha ( 0, 0, fg_color, i + 33, bg_color, font, temp_buffer ); rendered_letters[i] = temp_buffer->buffer_ptrs[0]->buffer; } free( temp_buffer->buffer_ptrs[0] ); free( temp_buffer ); return( 0 ); }
