20 years ago
Software Config Control
Hi all,
I'm wanting to keep track of software builds. What I do on other platforms, is run an executable that increments a number stored in a file called version.h. Thus the executable reads the current number, increments it by 1 and then writes it back. Then in my code, I read the number as a string from that header file.
I need to run the executable everytime I build my project. (I'm sure there must be place to specify any command lines to be executed before/after building the project)
I'm using the NIOS IDE. Does anybody have any suggestions???
Tyrone
    Search for topic "touch file"
    This shows how to add a make file that will run the commands of your choice on every build. I use it to update the build time and date in my source code.
    Select project/properties from menu (or by right clicking your your project). In the properties select Builders and add a new builder before "altera generated makefile builder'". You can specify any command you like and your command is executed at every build before altera makefile.
    --- Quote Start ---
    originally posted by keijo@Jun 1 2006, 07:45 AM
    select project/properties from menu (or by right clicking your your project). in the properties select builders and add a new builder before "altera generated makefile builder'". you can specify any command you like and your command is executed at every build before altera makefile.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15740)
    --- quote end ---
    --- Quote End ---
    Thanx keijo,
    It seems to work great. Only thing is that when I rebuild it seems like the .EXE is runs twice as my version number increments by 2 everytime. It&#39;s not critical though, as long as I have something for now!
    Cheers,
    Tyrone
