21 years agosoftware (.elf) in onchip memory?
I'm using a custom board with an EP1C12 a flash, and a SDRAM module. I'm getting problems with the sdram module (seems that after download the elf via usb blaster to the sdram, the sdram g...
21 years agothank you Seu_xugh,
this is exactly what I need. I successfully compiled a small program that entirely runs on the onchip memory and now I'm able to make write/verify tests on the sdram. Cheers, Marco
