16 years agoSoft realtime with PREEMPT-RT for NIOS II
Dear all, We have made an effort to port PREEMPT-RT on NIOS II. It is possible to use PREEMPT-RT for NIOS II (with MMU) under Linux. PREEMPT-RT is a soft realtime extension for Linux. ...
16 years agoThis is absolutely GREAT as IMHO there will be lots of application for NIOS that will need a better realtime behavior and of course the MMU version of NIOS will be the way to go, anyway.
So I would very much like to see the "Realtime-Level" as a configurable option in the build system. AFAIK, at the moment there are two levels, your work might introduce a third one. BTW.: what are the cons to _always_ using the realtime extensions ? I understand that while the max latency is improved, the overall performance of the Kernel will be somewhat lower. Do you have numbers for that ? BTW / 2.: did the lack of atomic instructions impose any problems to your work ? -Michael
