21 years agoSOF2FLASH and EPCS16
Hi All, I've just started upgrading to Q4.2 (with sp1 added) and NIOS1.1 during a project lull and I'm having a few problems getting my bootloader running (which was previously fine ...
21 years agoHi,
With regards to sof2flash: Yes, this is normal behavior. We are passing in the largest EPCS device available.... at that stage in the conversion process it does not matter which specific EPCS device is targeted; the utility is just converting quartus programming file formats around to something it can use to create a .flash (i-hex) file later in the process that will be programmed to the EPCS chip of your choice.
