19 years agosof and elf into epcs with quartus programmer
I've searched Altera and this forum pretty extensivly and have not found the answer to this question. Is there a way to take the FPGA configuration info and the NIOSII software and create a pof ...
19 years agoYour choices are:
1. Upgrade your toolset... 5.0 is darned old and, if I remember correctly, doesn't support what you'd like to do. - NOTE: You'd have to write a custom bootloader using this methodology. 2. Use the Flash Programmer....not sure why you have an aversion to it in the first place. Regards, - slacker
