gyuunyuu
Contributor
6 years agoSlow clock domain peripheral generating interrupt for a fast clock domain Nios takes too long to clear.
A Qsys custom peripheral is running at 33MHz and generates an interrupt that goes to a Nios runnign at 99 MHz. The Nios then has to clear the interrupt by writing to a register in the custom compone...
Ahmed_H_Intel1
6 years agoHi,
I see you can create an external block like an RTL block running at high clock frequency to be as a bridge between them to take the interrupt from your custom peripheral and send to NIOS, once the NIOS execute the interrupt and writes to the register the RTL block de-assert the interrupt as it is running in a high clock frequency.
You can also check the VIC Victor Interrupt controller IP in Qsys.
