ZVere
4 years agoSlow access to avalon from NIOS
My baremetal NIOS application is writing to 32bits registers in the FGPA via AVALON bus.
The code is:
void GwbrWriteWord32 (alt_u32 Offset, alt_u32 Data) { IOWR_32DIRECT (0, Offset,Data); } void WriteMyRegister (alt_u32 Val) { GwbrWriteWord32 (MY_OFFSET, Val); } int main (void) { WriteMyRegister (17); WriteMyRegister (17); return 0; }
I measured the time required to execute "WriteMyRegister" with Quartus and got 146 clock ticks. The clock is 100MHz so the time is: 1.46usec
Does it make sense ? It seems very slow.
Do you think I can make it faster by changing the code ?
Thank you,
Zvika
1 Reply
- EricMunYew_C_Intel
The long latency that you got is correct due to the fact that IOWR_32DIRECT is bypassing data cache.
