15 years agoSize of RAM needed to store NiosII code
Hi, I'm currently working on porting a project from an Altera Dev Board (Nios II Embedded Evaluation Kit, Cyclone III Edition) to a self-designed PCB board. Currently, I have some code fo...
15 years agoAdd the values together and compare against the size of the available memory block!
17k + 12k = 29k I suspect that is a 32k on-chip memory block 28k + 4060k = 4088k Looks like 4MB (4096k) The other few k is probably bss and other pad space. (The standard linker script probably puts a gap between the code and data for mmu page permissions)
