12 years agoSize of C file running using NIOS II ON CHIP RAM
How to figure out how much amount of space is being occupied by the C.c file which is used to to run as an NIOS II hardware ?? For example in the file http://www.altera.com/literature/hb/extern...
12 years agoUse the nios2-elf-size utility on the corresponding .o or .elf file.
Search for "nios2-elf-size" in this document: http://www.altera.com/literature/hb/nios2/edh_ed51004.pdf
