21 years agoSIOCSIFADDR error
This is a custom board. I have taken everything out except for the Flash and SDRAM. It is actually a fairly simple system, flash, sdram, and an ethernet port. I don't use tightly_coupled_memor...
21 years agoThanks Doug for your reply.
It is very consoling to see that I am not the only person suffering with these problems. Last week I was so elated even to find a hit on my search for "m_state == STATE_DEBUG". I get so many communications problems with the JTAG UART that this is an almost impossible problem to debug. I tried a "grep" on the message in the entire /kits directory and could turn up NOTHING. At the very least I would like to see this message in C source and atleast know for sure the cause of the problem. By the way, do you even have an occasional comm problem with your ethernet port? -Baycool
