21 years agoSIOCSIFADDR error
This is a custom board. I have taken everything out except for the Flash and SDRAM. It is actually a fairly simple system, flash, sdram, and an ethernet port. I don't use tightly_coupled_memor...
21 years agoBaycool,
Nope, I never did figure it out. I do know that I can connect to my board through the ethernet port with out any problems. Everything works fine here, I can telnet in, ping it, and the web server runs just fine. I'm pretty sure this is a JTAG UART issue. I just don't know what yet. I'm working on trying to figure this out. We got another custom board back late Friday. I will get that one up and running to see if the same problems arise. I tried your trick of opening the IDE first. It still bombed on me. I'll let you know if I find anything out. Doug
