12 years agoSimultaneous open of two UART on a single NIOS II
Hi, I searched before post but I didn't find anything so I hope nobody asked this before. I try to use several (three on my final application) UART on the same NIOS and connected each othe...
12 years agoGo into the BSP editor, and under the "Advanced" section, increase the value of hal.max_file_descriptors.
Also, it is not strictly necessary to use reduced drivers if you just want non-blocking access. If you're using the full HAL layer, you can also use fcntl() to set O_NONBLOCK on the device. (This does not appear to work on the standard streams - stdin, stdout, stderr - but it should work on a device you have opened with open().) Keep in mind that this will make the device non-blocking for both reads and writes; i.e. check the return value of write() -- don't just assume the character was sent.
