15 years agosimultaneous access to ddrII memory by nios and vhdl entity
Hi all, I am using Arria II device.Basicly,what i need to do is to transfer large amounts of bulk data,which is stored in DDR2 memory using Ethernet to PC.The problem is that vhdl-based entity is ...
13 years agoQsys generates a round-robin arbitration scheme. You can apply weights by increasing the arbitration share on a per master-slave pairing basis (Qsys uses slave side arbitration). This is just a system setting, your master doesn't need to do anything special for this.
From the master perspective all you need to do is make sure you heed waitrequest. If you issue a read/write and waitrequest is asserted then your master just needs to stall until waitrequest deasserts which completes the access cycle. So it's not like a shared bus architecture where you need to worry about tri-stating your master when the arbiter kicks it out.
