15 years agosimultaneous access to ddrII memory by nios and vhdl entity
Hi all, I am using Arria II device.Basicly,what i need to do is to transfer large amounts of bulk data,which is stored in DDR2 memory using Ethernet to PC.The problem is that vhdl-based entity is ...
13 years agoI have a similar problem. You say that you build a Master into your component, but what do you use for this. If I don't want a DMA, do I use the Avalon-MM Master Translator to begin with? If not, what component?
